Blem White resin
DO NOT EVER USE THIS JUNK. Blem has made a resonably good 1st attempt at boat building into a horrible experiance. I have had to remove the 3 coats of interlux because of the blushing issue but the worst part is the amount of sanding required becuse this junk won't flow out!
Beware, and stay with MAS.
I'm sorry to hear about your experience with Blehm resin. I had never heard of them before. Was it their surface coat resin or laminating resin that you used?
www.blehmplastics.com
