Hello, After about 12 years of service, the deck pads on my Kaholo 12-6 are starting to lift from the deck in about a half-dozen spots. Each of these bubbles is about the size of a quarter to half-dollar in diameter. They’re not on the edge of the pad and pushing them down doesn’t do much. I tried poking them with a needle to force the air out in hopes of getting the pad to re-stick but that didn’t work for long. Wondering if using a syringe to inject some kind of glue might work or if there’s another solution short of removing and replacing them.
If they are twelve years old the problem will probably continue to grow, so I’d replace them. Obviously you can buy replacements from CLC but there are many other options available at lower price. We never used the ones in the kit because the customer (my bride) did not like the gray color. We found some she liked on Amazon and they have held up well.
Thanks, Mark, I hadn’t thought of another pad option. Nice to know they exist. Any chance you’ve heard of an safe/effective way of removing pads that are still 95% adhered?
Beautiful Kaholo!
CLC uses Seadek. I found this: How to Replace SeaDek
Thanks for the lead!
