Recently I started a Chesapeake 14 build from plans. I did not buy a kit as the boat is for my 9 year old grandson and I wanted to build the boat at a 95% scale and use 3mm plywood to minimize weight. I happen to live in the Boston area so I have a great source of marine plywood (Boulter’s Plywood) and a local CNC operator who charges a nominal amount
. My normal process would be to take the plans and enter the panel offsets in a CAD tool (I happen to use QCAD pro) in order to generate a DXF file to send to the CNC operator. Things are much easier with AI. I created a simple spreadsheet of the bottom and side panels with the offsets from the plans and asked Claude to generate a DXF file for the two panels. A few tokens later Claude produced two DXF files which I hand checked in QCAD for accuracy. Next I asked it to shrink both by 5%. Finally, I asked Claude whether it could split the panels width-wise and add puzzle joints. It was glad to do so but first wanted to know what size router bit the CNC operator would be use. It then proceeded to produce 4 dxf files which I sent off to the CNC operator for cutting. As the attached photo shows the resulting joints were perfect. Frankly, as a former CS professor I was simply stunned by what Claude was able to do
