Custom clamp ends for angled pieces
I always find it difficult to clamp the ends of the kayak during planking. I have used the wood wedges with sticky-backed sandpaper and that worked great, though it can be difficult to hold everything in place while clamping. I came up something that seems to work well so far. Ball-joint pieces that mount on Irwin trigger clamps (after pulling off the soft covers). They will work on compound angles due to the ball joint.
I’d by happy to post the STL file (if that’s possible) if anyone wants to print a set. These were done on a Stratasys in ABS.
Those are a great idea. Maybe post on printables or makerworld and then post the link on this forum. But would you be willing to post the STEP file so that others can modify the clamp pieces to accommodate other brands of F clamps.
And I don’t think ABS is really necessary. It would seem Petg with 4-5 walls and 20% infill would be plenty strong
Good idea. It’s an Inventor file , but I can save to STEP. The only trick in deciding what to print it with is that it’s a single part with support between the ball and socket. I had to clean it for several hours to get the support out of the narrow space.
I put the design on Thingiverse. I added an alternative design that may print easier.
https://www.thingiverse.com/thing:7421594
