WILL USING (AC) & ACCELERANT, STAIN OR DISCOLOR A CLEAR FINISH ON YOUR KAYAK PROJECT
I've used CA glue with accelerant several times with no problem however the glued areas were always sanded. SEEYA Jack
It can make your caps lock key stick on, though.
It doesn't like to take water based stain. I had to repair part of the coaming on a WD12 and used CA glue. The glue made lighter spots, where the stain didn't take. Good Luck, JRC.
Used cyanoacrylate glue on my puzz;e joints as well as stain and it turned out fantastic. I sanded the joints and they took the stain very nicely. I also used Laszlo's tape technique. It worked well. Not as nice a line as his but after a little sanded or alot of sanding in spots it turned out well. The photos are attached:
http://i58.tinypic.com/2v1vju1.jpg
http://i62.tinypic.com/zmxcpf.jpg
Chris
Here are the pictures:
