Eastport Pram Mast Step Catastrophic Failure
The mast step in the Eastport Pram broke off. The pictures below show the mast step and where it connected to the hull. I see that the two forward screws holding the step to the hull also broke off with the step, but there is no hole in the hull itself.
This Eastport Pram was purchased secondhand a few years ago. The original build was around 2009, so this uses the Mark 1 sail rig for the Eastport Pram.
What is the procedure to fix this mess? I think the forward seat deck might have been stressed or cracked when the mast step broke off. I should probably plan to reinforce the seat deck mast hole as well.
This part gave 17 years good service. I’d just remove all the old parts, fabricate a new one and epoxy it in.
Looking at the pictures the thing that stands out the most to me is that the failed parts are dimensional solid lumber that failed along the grain. The failed surface also looks to have absorbed some water in the past and the arrangement of the screws holding it all together looks odd.
If that was my boat, I’d do like Jon says and entirely replace the step. Further, I’d use 3/4" (18mm) BS1088 marine plywood, the kind with the 10+ plies, that is at least 10 plies, more is better (CLC sells 11 ply stuff). The large number of plies will prevent it from breaking along the grain again. You can buy it from CLC as a 2’x4’ piece which will help with the shipping. You can also call and ask them if they have any scrap pieces they’d be willing to sell you. Scrap in this case means perfectly good wood left over from cutting pieces for kits that are too small to go into another kit. All they can do is say no if they don’t and you may be able to find a deal.
When you make the step, consider adding big fat fillets at all corners to smoothly transfer the forces from one piece to the next. For the next level of strength, put fiberglass tape over the fillets.
Again, if that was my boat, I’d permanently remove the screws, plug the holes with dowels and epoxy/woodflour glue, sand it smooth inside and out and lay down a piece of glass over the area so that the new plugs are encased on both sides. The step itself I’d bed in epoxy/woodflour putty and form the squeeze-out into nice fat fillets. Once that cures it’ll hold just fine without screws, but if you’re nervous, put tape on the fillets.
Hope this helps,
Does anybody observe the coin under the mast tradition?
I had a Canadian dime with its gaff-rigged schooner and a Hungarian 1-forint piece under the masts of my schooner. Nothing for boats since then (if I don’t pay I guess I won’t be going to the underworld).
I wonder if by now it should be a cellphone running a rideshare app?
I used to put Thaler coins under the deck glass on my kayaks.
That makes sense, but I’m still wondering what is the best way is to remove the screws. I assume the remainder of the step’s solid lumber is epoxy glued down, how is that removed. This section of hull has glass on the inside and out, any special handing for that? I think I can manage rebuilding the step, but returning the hull to a starting point has me intimidated.
Also is there an easy way to remove the Seadek so it can be put back afterwards? Just added this season along with new varnish and paint.
I’ve never been able to remove SeaDek in one piece, it just sticks too well. maybe a heat gun? But then I’m not sure that it will be replaceable. I’d just plan for a new piece.
The solid lumber can be removed with a chisel and belt sander once the screws are out, if you can get the sander to fit in there.
Once the wood is off, you can sand the epoxy residue off with the sander. Use finer grits to get you down to clean glass. Or you can continue with the coarse grit and get down to bare wood. Alternatively, score the boundaries of the glass that you want to remove with a razor knife, loosen it with a heat gun and peel it off with pliers.
Removing the screws can be done several ways. You can remove the glass from over the screws and pick out the epoxy from the slots, then remove the screws with a screwdriver. If they’re recalcitrant, hitting them with a heatgun may help loosen them (also with picking out the epoxy). If they’re still not cooperating then drilling out may be the way to go. It’s the most drastic but overall it may actually be easier and the holes are easy to patch with dowels and epoxy/woodflour.
