I ready to bring the ends together, how wet? and how long do I let it soak in before I start bring the ends together?
Coach C
Coach C
Sort of trial & error- or rather try & try again. I would spray with hot water and wait 5-10 min ( I don't remember specifically) then try to pull it together. When I couldn't get it together all of the way I tried again. You can use the wires to hold it part way together as you work. I think I also tried hot water soaked rags for awhile.
I do remember trying several times- including rough shaping a piece of wood, placing it in the stern, and temporaraly screwing the sides to it.
Thanks Ralph, it went together pretty easily. I am now trying to figure out how the transom fits in. Any help will be appricated.
Coach C.
