Epoxying the shear clamps?
I am not sure if I made a mistake here but I epoxied the shear clamps in the bow. The instruction say to do that but perhaps they meant just the undersides? I wonder if epoxying the tops and sides will make planning more difficult? Anyway, after 2 ½ hours of epoxy and wood flour slop I am happy with the results.
Hi Luke,
that looks really good. on your direct question, yes, you want to paint the shear clamps with epoxy as they will be exposed inside the hull and you want to prevent from getting into the wood.
that said, you will plane the tops of the shearclamp off to fit the deck. So you will shave some of what you applied off. But it doesn’t really impact the amount of work to plane it. Epoxy is pretty easy to cut with a sharp block plane. You would probably not even notice the difference.
one ‘pro-tip’ while you are in this phase. if you have not already looked at the seam between the shear clamp and where it attaches to the hull side on the bottom, and inspected for any gaps or pits or crack in that seam, do it now and ensure you have a ‘micro fillet’ of untickened epoxy between the bottom of the shear clamp and the hull plys. think of it this way, if the boat is turned upside down with water in it, it won’t find a way to get inbetween the sheer clamp and the hull plywood. the best time to do this is actually when you glue the sheer clamps to the hull…so if you didn’t do it then, now is your last chance to do that.
again, your pictures look great. keep up the good work.
Thanks. I have heard/read different things about when to apply the second coat. I finished up around 10–10:30. The epoxy is now no longer sticky. But has that “soft” uncured feel. I read it can be done after 4 hours or up to 30 hours with the MAS slow hardener without having to prep the surface. I also notice a blob that ran off one of the chine fiberglass tapes and some runs on the hull panels. This will, of course be under the deck and unseen but I wondered if I should shave off the blob just for eliminating added weight?
I’m a blob shaver and yes it will save weight. While this one shave won’t make a significant difference, a consistent focus of care will add up over the entire process.
For me on the second coats, i tend to wait untill the first layer has cured enough that you can sand it which means that the cure is relatively solid vs taffy like.
The advantage of a bit of a longer wait is you confirm the first layer cured properly and you can use a sanding block with 80 grit to knock down any bumps or runs. I also like to sand the edge of my tape to knock it down a bit and to ensure i knock down any glass edges that are sharp.
Even though it will be out of site, if you have hatches or ever have to touch the inside, you dont want it to cut or tear your hand or anything else you tuck under there.
H
Keep in mind that hardened epoxy dulls blades, so keep an eye on the cutting action and leave time for sharpening.
I saw Dillon Majoros, an ex-CLC boat designer, building a kayak with sheer clamps and he ran them across a router table with a roundover bit to eliminate the corner on the inside bottom. He did it for weight reduction and to keep the kayaker’s knees from being dinged.
