Hatch placement/Chesapeake 16lt
I am getting ready to add hatches to my Chesapeake 16lt. The manual says to place the forward hatch 2 inches in front of the forward bulkhead and the stern hatch 8 inches behind the cockpit. I moved the forward hatch 6” from the forward bulkhead (I measured where the bulkhead was from inside the cockpit) to make room for deck rigging. I was thinking of moving the stern back towards the stern more or is 8 inches enough for the rigging? Should I move the forward hatch back towards the bulkhead or is it ok to move it closer to the bow? I don’t want to mess with the structural integrity by adding hatches too close the narrower parts of the boat.
Hi Robert,
i would not worry about any structural integrity issues as a consequence of moving the hatches away from their design locations. However, if you are new to building, sticking with the proposed locations is often the safest approach because there are other interactions that may come into play that may not be easy to anticipate, without experience, that can impact the success of the move.
that said, i routinely move my hatches from the proposed locations within a couple inches to allow for some particular preferences i have. on the Chesapeake’s, the main thing you need to pay attention to is avoiding a hatch and any under deck hatch structure (i think there is a doubler that is installed underneath the opening of the hatch) from intersecting with the bulkhead and shearclamps. ensuring the room for the rigging you intend to install is another important interaction.
to the extent that you start to make significant adjustments of location, the curvature of the deck may change and the formers underneath the hatch itself (which bend the hatch to the curve of the deck) might need a bit of a tweak.
one other thing i typically do is not cut my hatches until after i have the coaming done so i can lay out my rigging and hatch locations with temporary blue tape and ensure i am comfortable with the spacing and do some testing to ensure i have the room i want with the rigging to have enough space between the coamings and rigging and hatch.
the picture below, while not a chesapeake gives the general idea. the cockpit/coaming is done and the blue tape is showing the anticipated rigging location before the hatches are cut. the focus then is ensuring it all works together for my preferred rigging plan and then just need to ensure the hatch and related structure is deconflicted with bulkheads.
hope this helps
