This is not an original idea so many of you are likely to be using foam sanding blocks on curved surfaces. Rebercca Wittman the guru of brightword gave me the idea in her book. Buy a coarse foam block and wrap your favorite sandpaper around it. It works so much more effectively on curved surfaces than a hard block.
