NE Dory - Tacky Tacks
I’m at the stitch phase of my Dory build. The port side turned out very well, just as shown in the manual. The starboard side, where I started, was a challenge. I overthickened the epoxy a bit and put way too much on. Is there a good remedy for this or am I in for long days of sanding?
Nice work on the port side, those tacks look clean. A sharp cabinet scraper takes the lumpy ones down quickly while the epoxy is still green, a lot less sanding than waiting for a full cure.
Just a comment in general. I think I’d make a poor preacher, as I’m having trouble spreading the gospel (-gospel according to me, anyway). CA for tack welding (in most cases), and even when using epoxy, the absolute minimum number of tacks and tack sizes! The tacks only need to hold the boat together for long enough to pull wires and lay in the filets, and the filets go in so much better when not trying to run your “perfect”, consistent filet bead over big, lumpy tacks (or even worse yet, wires (pull those prior to filets, too). Not to mention that you can start pulling wires an hour after using CA tacks (with the spray hardener) and move on to doing filets, or even sooner if you are brave.
So, Daniel, great to see your progress. But yes, looks like you will end up devoting some time to cleaning up the overzealous tacks. And don’t worry, I too started where you are with respect to knowledge and technique. Things will get better - just try to avoid hard lessons by learning from the mistakes we others have already made. Sanding hardened epoxy is probably the least pleasant part of stitch and glue building. Everything you do to avoid it is of great benefit.
And before moving on to doing your filets, spend some time looking through the forum and videos for how to achieve virtually smooth, almost no sanding necessary filets. The short version - lay in the right amount of thickened epoxy of the correct consistency, tool it and clean up the edges as soon as it is laid in, then smooth and shape when it is in the just right “plastic” stage of fimness, using a finger dipped in alcohol or unthickened epoxy. You might try a foot-long test filet on a scrap joint. I haven’t looked to see if there is any video, but was present at a Port Aransas (TX) wooden boat show where John demonstrated the technique.
Jeff,
Let me join you in the starving preachers’ pew. :slightly_smiling_face: No matter how often I rant about it, people still keep calling them tack welds. Welding is heating workpieces until they melt and flow together. Try that with wood and you get ashes. This is bonding, not welding.
I take your point, I’ll try to get the religion. And we drive on parkways and park on driveways, so there’s that, too. :slight_smile:
Thanks for the great advice Jeff! I did try scraping a few of them with a cabinet scraper as Matt previously suggested but either I’m doing that incorrectly or the epoxy is already too hard. I’m definitely going to try a test fillet. I saw another suggestion about brushing with unthickened epoxy as well.
Daniel, are you scraping down the fillets or across them? I put a radius on the corner of one of my scrapers and used it to clean up my lumpy fillets on my skerry working down the length of the fillet. It saved me hours of sanding (I was a little overzealous with the filling) and I found it easier to avoid taking off okoume from the adjacent panel than when sanding. Any extra big bumps I knocked down with a riffler file first, then went at them with the radiused scraper.
Another note, the scraper cut better and held a burr better after I invested in a single cut file to square it with and an accu-bur to roll the burr with.
Sage words from Jeff and Laszlo, I opted for Laszlo’s trimmed chip brush technique when smoothing fillets with unthickened epoxy as Jeff described and boy did that ever make a difference.
I think I have better pictures somewhere if you’d like them (or details of something else), but the top one shows the ribbons of epoxy peeled off by the scraper (this was over two weeks cured at the time, by the way), and the bottom shows (albeit with poor focus) the finished joint ready for glass.
It really isn’t the act of “brushing” that really does what is being discussed. Although a brush might work in some situations, in most you need to use a gloved finger. You’ll see what I mean when you try. The fluid (alcohol or epoxy) acts more a a lubricant as you smooth and form the final shape of the filet. I almost always use alcohol, as it involves no mixing, no clean up, no worry of drips, no epxy waste and lets you choose the exact few minutes that you work on each filet based on its plasticity. And all filets will end up getting overcoated with epoxy, anyway, when you do final coating of the whole panel assembly as a unit.
As to scraping hardened epoxy, a sharp scraper works at least as well as sand paper on flat portions of work (and will need subsequent light sanding), but in edges/etc. you’ll usually need a dremel, rasp or sandpaper.
In your case of overfilled tacks, you just need to get them to a point where you are sure you filet material will cover over all the tack material. Then you’ll just have to work a little harder to fill in a consisten looking filet bead over the underlying lumpy tacks. When you don’t have tack lumps in the way, making filets with a pastry bag is rather easy, like laying in a bead of caulk.
Someone replied to your post.
| Daniel_De_Deker
November 3 |
