I put this in the wrong forum, one more time. I got some resin(about an ounce) in my one half gallon of hardner, will this spoil the hardner, it did plug up my pump, now I,m afraid to use it. I don’t want to mess up another pump.
It shouldn't mess up the hardener. It should only react with about 1/2 an ounce to make a hard lump (or lumps) in the bottle. After a couple of days (or less), the resin should be all reacted. Just replace the pump after the reaction is done and you should be fine.
Can you see any lumps in the bottle?
