Has anyone painted a graphic on their wood duck before glassing the hull and if so does it matter if you use oil or acrylic? Thanks
I've had good luck with oil artists paints. I painted on the finished fiberglass but before varnish,so I could remove mistakes.
duh…why didn’t I think of that?..great idea since I belong to "Misteaks R Us"!..thanks…DO you know if varnishing a yeraly thing?
