Planning screwup
I really messed up the planning on the port foredeck area in front of the deck beam. I am dumbfounded on how it happened. I guess the more the planning guide showed a gap I just kept on planning. What now? After the deck is on do I fill in with a resin mix of wood flower and the Cellofill?
resin?
One thought would be to fill it in with whatever then add a rub rail after the fact to cover it.
Hi Robert,
by the looks of it, you are showing the planing between the front and of the cockpit and the forward bulkhead (or is it the rear bulkhead?). It looks like you probably removed too much material on the inner side of the shear clamp such that when you put the deck on, there will be a gap between the inside sheer edge and the deck.
that’s ok, totally fine. nothing that can’t be addressed.
when you place the deck, the most important thing is to minimize the gaps on the outer surfaces (i.e., the okoume of the deck touches the okoume of the side panels and that you did not significantly cut into the okoume side panels). the inside edge of the shear clamps can be a bit more sloppy and nobody will notice.
when i look at the pictures, notwithstanding the shearclamp problem, the okoume side panel appears pretty on track.
so when you glue the deck, you can anticipate you will have a bit of a gap on the inside on this section. the simple answer is, you will, after glueing the deck, fill in any gaps between the sheer clamp and the deck with cellofill thickened epoxy.
from a deck glueing perspective, it is important that you totally coat with thickened epoxy the top of the shear clamp and leave no exposed raw wood. on this kind of construction, the possibility of having a gap like you are predicting is always there so you want to ensure befor the deck goes on the boat has no exposed wood and that includes the top of the shear clamps that you are planing now.
one way to ensure that is simply to paint the tops of the shear clamps with unthickened epoxy before the thickened epoxy you will use for the actual glueing. and i would recommend that.
when you go for attaching the deck, on areas where you think you will have a gaps, you can put more thickened epoxy (this should be mayonaise thickness) then you would on the remaining sections…and it may be enough to fill the gaps, but after you are done, if you have a gap, you can just put some thickened epoxy on a gloved finger or popsicle stick and fill in any remaining crevasses you can reach.
hope this was clear and helpful.
Howard,
Thanks again for talking me “off the ledge.” It mat not be so bad once I blend the fore and aft with that section. Thanks for the advice.
Cheers,
Rob
Daniel,
Thanks. I am relieved to have options.
Rob
