My daughter and I are building the sport sectional kayak—first time builders. As we were applying the initial coat of epoxy to the fiberglass on the deck we ran into an issue: the epoxy was starting to cure and getting too thick but we only realized the problem after brushing some on and we were unable to fix it. As a result (see photos) it looks like the epoxy went on too thick and may have raised the fiberglass (it looks white but there’s a lot of epoxy there). What is the best way to fix this? I was wondering if we should sand that area down to level of the good areas, and reapply a patch of fiberglass, draping it from one shear panel to the other going to the edges where the shear panel meets the side panel, and then apply a proper coat of epoxy. Once fill coats of epoxy are applied, does the fiberglass disappear (e.g. can you see a patch if properly feathered?)? Related question: is the correct amount of epoxy to initially apply over the fiberglass one in which you feel the weave after the epoxy dries? We mostly did that, though there are sections where it feels smooth, as if we might have overapplied epoxy.
You are going to need to sand that area back to bare wood. Use 120 grit or 80 grit paper but you need to work slowly. You must wear a respirator and safety glasses as ground fiberglass dust is very dangerous to breathe. Best to do this outside and with a random orbital sander with an attached vacuum. You might consider wearing to a disposable full body suit. If not clothes should be bagged and then taken inside to be washed.
Also, what epoxy are you using, how big of batches of epoxy are you mixing, and how warm is it wear you are working? Have you watch any of Nick Schade’s YouTube videos on fiberglassing? If not you should
We’re using the MAS epoxy that came with the kit (slow hardener). I think we just had too much in the cup. We now realize some of the tricks (mix less at a time, use a wider container, etc. I tried a heat gun on one section and couldn’t get it to flow (about 24 hrs after we glassed and epoxied). I then sanded down almost to bare wood. I assume I need to sand more and then put down another section of fiberglass f/b epoxy? I have a Festool vac and sanders and have been wearing a good mask and clothes dedicated to epoxy and sanding but not a teflon suit (though I think I have one somewhere).
Whew. You could not have a better combination of sander and vacuum for doing such a job. I once hated the finish of a 17’ canoe I built. It was West 105 epoxy but for some reason the finish came out super cloudy. I was fortunate to have access to a 20’ spray booth with full filtration to sand all the glass off. What a truly miserable experience.
It helps to pour the epoxy immediately after fixing into a small roller tray to increase the surface area of the epoxy which help dissipate the heat generated. If you are a novice maybe really small batches like 200 grams of resident and 88 grams of hardener. BTW I am a big advocate of weighing both components on a digital kitchen scale. Super accurate and a worthwhile investment for $20. I slip mine into a gallon zip lock bag that gets tossed every once in a while
Thanks. I think we’ve now learned our lesson and are more confident mixing and applying epoxy. The question is what do we do now. One option is just leaving it as is. I don’t think there is air under the glass, I suspect it just didn’t wet properly. My sense is that this is a cosmetic issue given the location so we might just leave it as is and consider it a battle scar of our first build (and it’s a kayak, not heirloom furniture).
That would be fine but I think it is pretty easy to sand it back to bare and fix it. One last comment. I personally don’t use a brush or roller to apply the first coat of resin. Instead I pour the epoxy on and then use a 4" squeegee to spread it around working. The goal is no shiny spots but not starved for resin
That glass needs to be removed. It’s not properly wet out so it’s a target area for delamination, micro fractures and the start of rot, in addition to all the cosmetic issues. The deck, especially near the cockpit coamings, is an area where there’s a lot of flexing, especially as one gets in and out of the boat.
The good news is that a heat gun makes removing the glass a lot easier and cleaner than sanding. The heat will soften the epoxy and reduce the peel strength. A putty knife and pliers will usually do a quick job of removing the glass and a light sanding will give you a clean surface and boundaries for the new glass.
To avoid this problem in the future, if an area of glass does not wet out properly, peel it off while it’s still uncured. If glass does not turn transparent within the first 5 minutes or so, it never will; there’s no point in waiting for it to get better. Since it takes hours to develop its peel strength, you’ll be able to remove it by peeling much more easily than by sanding it off.
Thanks Laszlo. Any tips on using the heat gun? We tried to get it to soften the epoxy and worked on it for a minute or so but it started to make the epoxy brown and it started to smoke as if we were burning it without really softening it. Also, the glass on the deck is one continuous piece so will we be able to tear off only that area?
-Rob
It sounds as if you hit it with so much heat that the outermost layer scorched before the inner layers softened. Take it easy with the heat. Use a lower setting, pull the gun further away, give it more time. The heat needs to soak through to the wood before the exterior scorches. If it all seems too tedious, remember that the alternative is noisy, dusty and potentially harmful.
Yes, you can limit the removal only to the poorly wet-out area. For starters, don’t heat the areas that you don’t want to remove. An aluminum foil shield over the good glass will help control the amount of heat dumped into it. Don’t fasten the foil tightly to the glass. You don’t want the metal conducting the heat into the good glass. Instead, tape the edges farthest away from the work area so that the heat gun doesn’t blow the foil off. This will leave a bit of an air gap between the foil and glass to insulate while the foil reflects.
When you’re peeling up the glass, stop peeling once all the bad stuff is up. You can try using a razor knife to score the glass before heating to limit how far the peeling will extend. Depending on how thick the epoxy layer is that could work well.
You will need to peel into the good glass just to make sure that all the bad is removed. That will likely leave a rough edge that will require cleanup with a sanding block and #80 paper. Once you’ve gotten rid of all the loose edges, use the sanding block to feather the existing glass. This will allow the new glass to fit smoothly over the old.
Thanks again. I watched a few videos before seeing your post and tried again, this time using a chisel. It worked well. I now need to sand but there should only be a need for minimal sanding now. I ended up removing the entire section between the cockpit and hatch figuring one continuous sheet would work well. I’ll apply a strip in that thin section abutting the shear strip. Pic attached is before sanding. I’ll post follow up pics as I progress.
-Rob
Follow up question: when we lay down the new piece of fiberglass over that area, how far should we extend it and epoxy it? Should we aim for the intersection of the shear panel and the flatter part of the deck or should we double up and epoxy the new piece over the existing fiberglass over the shear panel, down to the shear line?
For strength,adhesion and peel resistance, it’s good practice to have a 2-inch overlap when putting new glass over old. Feather the old glass edges so you don’t have a “cliff” for the new glass to go over. Air bubbles get trapped there and lead to delamination.
Thanks Laszlo, will do as you suggest.
Thank you. I should have known to suggest a heat gun.
Some follow-up: Thanks for the helpful suggestions. After removing the problematic fiberglass we reapplied new cloth, applied epoxy, and eventually filled the weave on the deck. The patch is essentially invisible at this point (photo below).
Neatly done. I certainly can’t see any line.
Thanks Laszlo, appreciate the nod!
Great recovery and you learned a lot I suspect. Deck looks great now
