I’m applying several coats of Interlux Schooner Bright varnish on the inside of my Skerry. I don’t have any satin varnish yet, though I noticed that my local big box stores carry Varathane oil based satin varnish. Is that any good? Or do I need to order the Interlux Goldspar Satin?
I always stick with the same manufacturer. Sometimes there are incompatibility chemistry.
I have done the combination with interlux you are proposing a number of years in the past and no problems.
Gemini says varathane is a not a varnish that is compatible with marine varnish; they are different and explains why and cites references you can check.
My understanding is that VARATHANE products are polyurethane finishes - unlike varnish. Here is a comparison chart.
The Varathane could be a good, easier to apply and more durable finish for the inside of your Skerry but good to check if EXTERIOR USE is on the label. In any case it will not tolerate exposure to sun as well as the varnish but for ease of application and yearly maintenance that might be an acceptable trade off to you if exterior use is part of the description.
Thanks, everyone. I drove a half hour and picked up a quart at a local West Marine. It sure is expensive stuff!
