Hey all, I could use some advice here. I repainted the interior last summer and sailed her happily and put her away for winter. When I uncovered her this spring much of the interior paint on the floor was flaking off in big sheets. I noticed a crack between the fillet and floor deck of the sealed voids. Once I sanded away the paint I revealed a longitudinal crack and movement when I push on the floor. I drilled a small hole at the base of the void and water trickled out.
So it appears that I have water in at least one floatation void. Any ideas on how I should go about accessing and drying that space before re-filleting the joint? I included a build photo to remind myself what’s in that void
First I’d find the leak. Is the damage from rainwater or from an intrusion through the hull.
Hi John,
i want to lead with i am an experienced builder but have not built a dory.
to start, it’s important that you dry it out, and as mentioned above, inspect the boat carefully and sort out any obvious source of the leak (e.g., a crack through the lapstrake). thinking through how this happened may help. was the boat stored upright or on a tilt to that side and filled with water that then went into the flotation tank from the cockpit? or must it have come from a gap in the lapstrake on the outside?
with respect to moving forward, i would install beckson hatches on all closed flotation tanks so you can easily inspect them for moisture and provide a way for them to dry out. you can find other conversations on the forum, but most of the experienced builders will shy away from any flotation tank that does not have an inspection hatch. water just has a way of getting into these spaces…so you need a way to detect it and allow it to be sponged out and dried.
the beckson hatch should be large enough and placed strategically above the low point where water would gather with the boat upright so that you can sponge out any pooled water and then leave the hatch off to allow the flotation tank to fully dry. this will be hindered somewhat by you foam flotation, so once you think it’s dry, give it another couple days. with the beckson hatch, you should be able to carve out some of the foam so you can see down to the floor on the backside of the flotation tank.
one thing you will also need to sort out is, did you put limber holes on the bulkheads that bisect that large flotation area? if not, you will need a beckson hatch on either side of it as each side has potentially two seperate flotation tanks under each seat.
before rebuilding i would also try to sort out if the bottom fillets should be taped with glass. certain joints are subject to a lot of flexing…and when that occurs taped fillets are substantially more resilient/strong compared to fillet material only. i would consult CLC or other Dory builders to get some insight into that.
the last comment, and again, i would consult CLC, on this…is was there an expectation that you fill the flotation tanks with foam. again, there is some differences of opinion in the community on this topic. but generally foam creates a situation that makes flotation tanks very challenging to inspect and keep dry. so most professional builders avoid filling enclosed spaces with foam. where additional protection is required, airbags that can be deflated and removed are a method used that allows for inspection and repairs.
I’m just in the installing foam flotation phase of my own SW Dory build. The CLC build manual doesn’t call for limber holes or inspection hatches. But since looking at the damage here in this thread on a slightly older SW Dory I think Howard is correct. Since I haven’t added my deck/seats yet I have opportunity to fix this problem before it’s a problem. I think another possible failure mode is the build manual calls for just filleting the footwell side to the glassed bottom. It says nothing about sanding that glass before you put the fillet in. I did sand first because I was worried it wouldn’t bond but if someone was following the manual closely they might not. Adding fiberglass tape to the fillets is also a smart move here. The top picture it looks like foil covered open cell Styrofoam was used on this boat. If so, that all has to go because it holds water.
Thanks for the feedback. I built the boat to CLC spec using the manual. As mentioned it doesn’t call for any kind of inspection port or pressure valve. The seats heat up quite a bit in the sun. I suspect all the joints have had a lot of pressure on them over the years. I have no reason to believe that the water is entering through the hull.
The cockpit has been full of water for some periods of time during storage from a leak in the cover. I suspect it was weeping through hairline cracks between the fillet and bottom deck. I pumped out the water and dried the boat before winter, but I suspect that moisture in the joint expanded during freezes and worked that crack bigger.
Thanks for the tip on the foam type. I’m going to explore the hatch idea and see if I can reasonably dig out all that foam and replace with removable air bags.
Yeah, with the motor well installed, this is the only place to stand in the boat which puts a LOT of strain on those footwell joints. I think these are good candidates for reinforcement.
Also Jon, I’ve had a lot of problems with the oar lock braces. When you get to that part in the build. Take some time to see if you want to reinforce that part as well. Mine broke every time I used the oars. That said, I was using oars that were incorrectly sized and putting too much pressure on the mounts, but they failed pretty easily.
Bunch of stuff to unpack here, but most of it already covered by Howard and Jon. I just want to add my endorsement of glassing all fillets. It adds a small amount of weight but a massive amount of strength for that amount of weight and it helps with waterproofing, too. The weight issue can be addressed by making the minimum possible fillets.
Another thing going on here is the type of foam being used. Personally, I’ve never been a fan of filling the voids with just anything that floats. My thought is that if you’re putting in foam, it should be the Coast Guard approved, 2 lb/cu ft 2-part expanding closed cell structural foam. That stuff adheres to the sides of the space, expands to fully fill the space and provides structural compressive strength. That means that it will strongly resist flexing that can cause fatigue failure of joints. It’s pricier than construction store foam sheets, but it’s actually designed for the job you’re asking it to do.
If I’m not going to use that type of foam, I leave the space empty with inspection, ventilation and access ports. There’s a new wrinkle to all this, though - cheap modern electronics. It seems that you can now buy borescope cameras for well under $100 (I found one on sale for $60 at Home Depot). These only need a 3/8" (9 mm) diameter hole for access. So on my last boat I installed a 1/2" drain plug in the flotation tanks. Unplugged, they provide venting as the temperature cycles and allow the borescope camera to be inserted for inspecting the integrity of the air tank and the state of the skeg mechanism. I also made the deliberate choice that if I ever need to get inside the tank for repairs, I would just cut a hole in the bottom, do the work and replace the cut-out. Since the bottom is covered in epoxy/graphite, this would result in an invisible scar. So this lets me have my cake and eat it, too - permanently sealed air tanks for flotation, venting for temperature cycling and ventilation, easy inspection and a method for repairs without hatches. The cost is needing a borescope camera and more work on opening and closing up for a repair, if and when it’s needed. For something like the Dory the hatches might be more reasonable, but I recommend a borescope camera however it ends up getting done. It can inspect hidden areas up to 15 feet away from the access point and take pictures and videos, as well as real-time viewing.
I’ve also made the decision that the only flotation mechanism I’ll use in an unsealed airspace is an airbag. They’re much easier to remove than foam and possibly lighter (though usually not).
Finally, when you do find the source of the leak in the Dory, be prepared to remove and replace some rotten wood. If it’s a crack along a seam, the water may have gotten into the edges of the planks. They may need to be shaved down to clean dry wood, sealed with epoxy and the gap rebuilt with thickened epoxy and reinforced with glass.
Good luck,
Thanks Laszlo, I just ordered a cheap borescope. Great idea
Ok, drilled a few holes. To see how far up the plywood wicked the water up. The endoscope was a dead end because all the foam’s in the way (damn’t).
I got the following response from CLC: “Thanks for reaching out. Yes I would most definitely install some hatches/access ports to air out the tanks. It might be a good idea to rebuild those fillets or locate the leak for repair.”
So it looks like I’m gonna install hatches and cut out the foam in 6” chunks!
Hang in there, you got this. For what it’s worth, I’m really very thankful you shared all this here, it has informed my build.
Any news Gene? How goes it?
Oh, you want the details?!? I traced the crack out to where it ends, cut out the fillets with an oscillating tool, and cut 6.5” holes for the becket hatches. I did a really good job of fitting the foam sheets in there, so had to drill and cut out foam for a whole day.
Good news is that there’s no mold or rot apparent, but water was wicking up between the foam sheets. I’ve got everything dried out, and have replaced the epoxy fillets. I’m going to add a strip of glass to the fillets and do a couple coats of unthickened before re prime/paint. It was a huge PIA, so glad you’re catching this on the build.
oh, also it looks like just the port side was leaking, so the new hatches will help me catch any new leaks if they happen.
You poor poor man. I’m so sorry. Where do I send the beer?
