Started my build SW Dory
Portside inwale is in the clamps. I did the graphite epoxy on the starboard side between the spacer blocks, the end grain of the spacer blocks, and the underside of the spacer blocks. A simple inspection mirror aided.
Starboard inwale is in the clamps. With plastic spring clamps it’s not if, it’s when…
Love the space’d inwales! Did you do all the spacers the same size? I am not there yet but maybe starting layout on Sunday. I think I want them to fall on top of the frames and I have 3 sets of oarlocks. I think that means they will have to be slightly different sizes to not have weird gaps.
Mostly the blocks are 2” and the spaces are 3”. I had to fudge a little here and there but it doesn’t seem to matter aesthetically. Honestly, I just followed the directions. I worked the spacing out with a pencil on some painters tape stuck to the shear strake, that helped a lot.
According to Fedex, at least one of my two Mantus Anchors are arriving today. Presents from my father. Thanks Dad!
This photo is from much earlier in the build, he had a short layover here in Knoxville and came by to see the boat.
