Hi, I’m in the process of deciding between a Passagemaker and Skerry and wonder if anyone has trailer-topped either on CLC’s Teardrop? I’d likely get wider load bars for the roof rack with either. I’m mostly interested in if works for something as long as a Skerry given the bar spacing on the Teardrop and if it’d run the risk of being too close to the tow vehicle. Thanks.
I own a Teardrop and until recently a sailing dinghy about the size & weight of a Skerry. I would most definitely not try putting a boat that size on top of a Teardrop. While the camper may handle the weight (and I don’t know that for sure) there are other factors that make me not want to do that.
- Vertical clearance could be a problem on some roads
- Stability issues. The vertical center of gravity would be raised too high making it likely to flip if provoked. Cars and pickup trucks weigh in excess of a ton and have 4 full-sized wheels. The Teardrop is some 500 lbs with 2 small wheels. A Skerry on top of a car or truck is no more than 5% of the vehicle weight, if that. On top of a Teardrop it’s 20% or so. It’s also adding sail area exactly where it does the most harm during crosswinds.
- Inconvenience. You’ve got to get it up there and keep it there. That involves a lot of time and effort when loading and unloading . You’ll also need to frequently stop and check the attachments while driving, as well as driving slower than usual and being aware of any strange or new sounds and vibrations.
Your best bet would be towing the camper and cartopping the boat, if you can. I have a set of ladder racks on my Tacoma pickup that I was able to put the boat on and I pulled the Teardrop behind the truck. It was still a pain to load and unload, but at least it was safe to transport that way.
Alternatively, just take kayaks on your camping trips.
Hi Laszlo,
I appreciate your detailed reply; I hadn’t considered several of the things you mention as reasons to avoid trailer-topping. It makes sense to car-top the sailboat instead. Nice to know you did it with a Tacoma as that’s what I have, as well. Thanks!
