Time between coats of resin
Is there a max time between coats of resin. i did a coat between 1:30 and 2:00 today but wont be able to recoat till tomarrow at around4:00…is that ok?
Probably. It depends on the brand and your weather conditions. Most quality resins are easily good for a day or two before you should sand. High quality no-blush resins are good for 3 to 4 days. Go to the resin manufacturer's website and check their recommendation (or at least tell us the brand).
Thanks for your response Laszlo,it’s system 3 silver tip…sounds like it should be fine.
