Trailering setup for Lighthouse Tender Peapod
My Dad and I are wrapping up our Peapod build and we were wondering about supporting the mast and spars, etc. while the boat is on the trailer. We are starting to build some supports that use the mast holes in the seats to support posts for a cradle. Suggestions appreciated and photos would be outstanding.
Different boat, but it is pretty easy to build a mast support that lashes to the scuppered inwales. The GIS has a transom so I just used a foam block there.
My Peapod has the balanced lug rig and a CLC Canvas Spar Bag to hold the mast, boom, yard and sail. The bag, with all the stuff, fits inside the boat lengthwise. With a bit of careful angling when loading, the ends of the bag (and the spars) slide under the knees and are held in place by the tension of the spars against the knees.
In other words, you don’t need to do anything. It happens naturally.
Just load the spars, including the boom & yard with the sail already bent on, into the bag and put the bag into the boat. The bag rests on the seats, the underside of the knees grips the ends of the spars through the bag. I’ve driven hundreds of miles that way without anything coming loose, but if you’re uneasy you can wrap a strap or bungee around it and secure it to the gunnel, oarlocks or whatever.
If you don’t have or don’t want to purchase or make a spar bag, you can put the stuff side-by-side and wrap a bungee around them and then put that package into the boat. But I highly recommend the spar bag. It makes everything much more convenient and lets you take the entire sailrig out of the boat for indoor storage in one step.
Hi Laszlo,
Perhaps the specs have changed a bit since you built your Peapod, or we made the mast too tall, but ours is about 6 inches too long to fit inside the boat. So we are looking for ideas and photos of how other owners have set up their rigs for trailering.
Thanks so much for your response,
Sean
