Does anyone have experience of sailing a Passagemaker lug rigged dinghy upwind? I can’t get mine to point much closer than 90 degrees, so inevitably end up rowing home! I am thinking of changing to gunter rig but not convinced that its the hull shape that is the real problem. If anyone has been able to get their lug rig to go upwind - I’d love to hear how.
I don’t have a Passagemaker, but have been sailing balanced lugs for years. The first thing I’d check is fore and aft balance. If you’ve got too much weight in the wrong spot you can induce lee helm which would keep you from going upwind. Typically it’s been sitting too far back for me. This can be fixed by moving forward or putting weight up front (passenger, drinking water, other supplies, ballast, etc.).
Another possibility is the sail shape. First, the draft (deepest part of the sail). You may need to tighten your outhaul if your sail is drafting too far forward. Second, twist. The leech (trailing edge) may be getting pulled too flat by twist and losing the ability to generate power. Reduce twist by tightening your downhaul.
Here’s a great discussion between a pair of PMD owners about tuning the rig.
Good luck,
Welcome aboard, Gareth!
I changed my Passagemaker from Gunter to lug.
I have limited time on either rig, but I don’t see a big difference. I sail on a small lake in Canada and generally have to beat upwind out of the small bay I’m on to get to more open water. The bay is about 500 feet across. It’s about the same effort with either rig. My understanding is that a lug rig is sensitive to how it is set up. I think there’s a fair amount of discussion on this forum about it. I know I asked questions.
Something else to keep in mind, depending on how you use the boat, is that the lug rig is so much easier to deal with. No stays, no fussing when the jib sheets get caught up, etc. on the other hand, the gunter rig is gorgeous.
Great point Lazlo about weight distribution. I have noticed that. Laying back in the stern does hinder performance.
Just realized your link was to my question when I first sailed the lug! The discussion there was helpful.
I had the knots for the yardhaul and downhaul slide a few inches on the smoothly varnished spars. Just an inch or two in the wrong direction on the spar and all upwind sailing becomes problematic. After re-alignment there was a vast improvement. Northeaster Dory Lug in my case, but something to check.
Using pulleys to increase downhaul tension really helps too if the wind picks up.
Wow, what a prompt and helpful response from everyone, thank you all so much.
I am sailing off the beach in Cardigan Bay, West Wales, UK. I am encouraged to hear that it is possible to sail upwind in a Passagemaker and that there is little difference between Gunter and Lug rigs’ performance. Weight distribution fore / aft worries me in that I already sit close to or on the centre thwart and can’t see an easy way of sitting further forward without a tiller extension and more side benching forward of the centre thwart. (I have built her with the addition of side benching between centre and rear thwarts). The halyard position on the yard is of course fixed by the hole through the yard - whose location I have checked as correct to drawings (40 3/4" or 103.5cm from front end). The downhaul position on the boom is however moveable and I have experimented with that, but to little avail so far. I think I need to be bolder and move it further forward on the boom. Does anyone have an ideal position / measurement of the attachment point to boom end? I have had it at 57cm and am thinking of shortening this distance to 44cm. I have increased the downhaul tension by fitting a small single block to the boom attachment point to give a 2 to 1 purchase.
Thank you again to all respondents.
If too much weight aft is the problem, you can stay put and put heavy stuff up front; no need to add benches and tiller extensions. That’s why I suggested that as the first thing to check, it’s the easiest. Bring along a child - a small movable weight that can independently assume different positions.
And tension the downhaul…a lot. The stock setup of a line going down to a cleat doesn’t give any mechanical advantage. So unless you get a couple of blocks to make a tackle you need to pull down with all your might, turn around the base of the cleat, try to get a bit more then tie it off tight.
You shouldn’t have to move much. I find it comfortable to sit all the way aft on the bottom which isn’t the best trim. But moving up towards the centerboard made a noticeable difference.
An update on my upwind Lug rigging adjustments: I have changed the halyard to be 4mm Dynema to remove stretching and thereby keep tension on the downhaul, and moved the downhaul attachment point further forward on the boom. The results are encouraging and I can now sail upwind! I am going to add a modest tiller extension to make it easier to helm whilst sitting on the centre thwart. Thank you to everyone for helpful advice.
Excellent! Happy sailing! It’s a nice rig on a nice boat.
