Which boat for 5'6" 146lbs..?
Hi all,
I'm looking to take part in an event next year called the Eddystone challenge, which is a time-controlled race to an offshore lighthouse and back.  It starts from Mountbatten breakwater (in Plymouth, UK) and is approximately 36kms.
I'm looking to build a boat to take part, as my current two are not suitable (one is 14' and the other is a double), but need it to be something I can use as a good sea boat too.  I need something with plenty of speed, but that does NOT require me to ballast the boat in order to get the correct trim.  I am not 100% against fitting a rudder or skeg, but would rather not use either if possible.  The prevailing winds are SW, which puts the winds squarely on the beam for both legs of the trip.
I'm currently thinking Night Heron S&G and Petrel with skeg, but lean toward S&G so I can get the thing built in time to have some practice paddling before the event.
Whatever I get I'd be importing the wood parts from the US because the cost of buying it here is high.  I'll buy my own epoxy carbon and glass, plus disposables.
Thanks for any thoughts...
Chris
The other boat is a Pax 18 with rudder, but how would it's seaworthyness compare with the other two..?
Chris
And I should just add that with all my kit I probably come in at around 165lbs.
I think that covers it!
Chris
Chris,
Take a look at Eric Schade's Merganser 16. It's 16.5 feet long and 21 inches wide. The hull is basically the same as the CLC Shearwater, which Eric designed. It's intended for paddlers under 5'10" in the 100-180 pound range. Eric sells kits for the wood parts only, which I understand are cut by CLC. I have a Merganser 17W that tracks and handles beautifully. -Wes
Here’s the link to the Merganser 16 page" http://shearwater-boats.com/merg1.html -Wes
