Any advice on repairing this damaged plank ?
You could try just cutting out the local damage carefully then cutting an exact match, sanding paint away from the edges for a few inches then stitching your new piece back in, tack weld with epoxy, remove stitches, Then add a layer of 5 oz cloth on both sides, fill the weave with successive coats of epoxy and filler, sand till smooth, prime and paint. I would be tempted just to cut two whole new strakes though and replace these two. It’s probably not much more work, but it’s a bit more time and expense. Have you shown it to anyone at CLC?
Thanks for your reply. I tried pulling the damaged plank back in place by driving screws through the plank into a batten cut to the curve of the hull, but that didn’t work. I’m worried that cutting out the damage and filling in with new wood might be very difficult because of the curvature.
hi John,
would like to know more about the batten…
if it were me i would create a batten that i would attach to the outside of the hull/along the strake using the good sections to bend it into place and then screws from the inside to drive the pushed in piece out along the batten then screw in place. you may have to clean out some of the broken wood to get it to mate.
once i have rehearsed that, i would then take batten off, cover batten with non-stick (wax paper or plastic sheet) so epoxy wont stick to it…throw thickened epoxy into the crack… and then redo batten pulling strake into place and let it set/cure.
once cured, i would use fairing compoud to fill in any bumps/fare the surface, recoat with epoxy and perhaps a layer of four oz glass. fare it in again and paint to match…
anyway. based on picture…that is what i would try first.
Howard,
Thanks for your input. I scribed a piece of Douglas fir to fit inside the strake and drilled holes through the strake in an attempt to pull the break together. The wood was just too damaged to go back into place, plus the rabbeted joint was cracked in both directions from the break. I have now cut out about a 2” section of the strake to remove the damaged wood and I can now get epoxy between the strakes and use C-clamps to pull the joint together against the batten inside. Then I can epoxy a broken piece that includes some of the fillet back into place. The last step will be to fit a new piece of plywood in where I cut away the damaged wood and then reinforce the patch with fiberglass and epoxy. I’ll try do document the repair with some pictures.
Regards,
John
