Another varnish question
I just finished sanding to 400g by deck on my Ch 17 kayak. After the first coat i noticed a few spots that appear like they are bleached out. I resanded, washed with soap and water, and revarnished. The spots did not disapear. Next, I resanded the spots on the deck with wet sandpaper to 400 grit and revarnished. The spots are still there. Next, I resanded and applied a thin coat of epoxy. Still have the "white spots" and sanding the epoxy and applying another coat of varnish. , I still have the white spots. Can anyone help with this problem. The rest of the deck looks great with varnish except for these discolored-white, clear spots. Please help if you can.
