Hey, I've been waiting for someone like you to post here. I fit into that category, threefold. A Wood Duck Double kayak that is under construction since 816 days, the Teardrop Camper 581 days, Chester Yawl 192 days, all at the 'a week before painting' stage. To answer the question of 'why three simultaneous unfinished projects?': my workshop has zero insulation. I can apply epoxy between late spring and early autumn, but in August it has been too hot the last two years. I can't paint approx. December to February. So I have a small time window for epoxy, and a wider window for paint works. I live in a remote area of Germany and there's no chance to find an affordable, better workshop. I have to drive 15min each way to get to the current workshop already. It is also fairly expensive for what it offers, so I still think it's reasonable (not pleasing) the way I have it now.
Wood Duck: didn't get it into shape for a long time. Viking funeral was considered more than once. Ended up applying lots of filler at the bow and a little less at the stern. Stern's a bit twisted, but otherwise the shape looks really good now. I won't allow anyone to use the fore and aft compartments. Will be painted inside & out. Maybe I'll varnish the decks and the coaming, but not sure yet, as I did a terrible job glassing the coaming, twice.
Teadrop Camper: used non-CLC epoxy with amine blush on that, didn't know it, and had to sand off an entire fill coat of epoxy later. During sanding I cut through the glass at min. 5 spots. Will fix it and paint the whole thing on the outside. Still confident I can varnish galley and interior.
Chester Yawl: thought I did it all nicely. When I applied outside primer, I realised my fillets are partially terrible and I didn't fill the wire holes properly (I had pre-coated the planks with epoxy, and even though I tried hard to fill before primer, I failed). Had to sand off the primer in the affected areas and applied small tips of wood flour epoxy on the wire holes I have yet to sand off. Shapewise it's all good, but the inside fiberglass job was mediocre. So I'll apply paint inside & outside. Rubrails will hopefully end up varnished.
There are many reasons why things are as they are. Anyway, I’m confident I can wrap up all projects within next year, and the results will be satisfying. I’m also looking forward to build one or the other additional CLC project (via Fyne Boat Kits), maybe a Peapod, and sureley a strip-built kayak. But that’s a couple of years away, until I have a proper workshop within walking distance...
Thank you for allowing me to let off some steam. All the best for your homestretch!
