Attaching oar lock risers
Quick question. Chester Yawl    I have thickened epoxied the oar lock risers to the gunnels, do I need to use any mechanical fasteners ? Will be using a a sliding seat.
i did spacered  inwales but I used a longer spacer so the entire oar lock is supported
Thanks for any advice
   While we're at it  is there something better than a drill bit for the 11/16 oar lock hole?
   I use Forstner bits with a piece of wood clamped underneath but I don't own a drill press so the angle didn't end up perfect.  I just used epoxy thicked with silica and so far they've held up. I tie a line from the bottom of the oar lock to the inwale incase it ever goes overboard
