Hey Eric,
First, I agree with everyting Joel said above. With that being said, I'm a plans builder who made a set of templates for both the Eastport Pram and the Passagemaker while I was cutting out the parts for the boat. Since the boats went together perfectly, I know the templates are accurate. It was easy to cut that additional layer at the same time.
My rationale for making templates was that it would cut several hours of laying out the paper sheets, punching them with an awl, then connecting the dots. I think that was about 20 hours per boat. My plan was that if I ever wanted to build another boat, I could just lay out my template, trace with a mechanical pencil, rough cut with jigsaw (I cut out all original parts with fine-toothed pull saw), then route to the template with pattern following bit.
I used 1/4" tempered hardboard/masonite for my templates. They're thin enough for storing all those parts between builds and strong enough to resist compression from the bearing on the router bit. They are a bit tougher to cut through and harder on the saw teeth. I went through two or three of those $11 saws from Harbor Freight.
I have router bits with the bearing on the top and bottom. I find that for smaller parts, the router bit away from the shank is better to put into the router table so you can spin the part around with the fence removed and the starter pin in place. For larger parts, I clamp the template/plywood assembly to the workbench, then using a bit with the bearing by the shank, I can trace around the exposed edge, then rotate the template as needed. I have two routers, so one is in the table and one is for free-hand (I won the second router for my Instructable on building the EP).
You'll need lofting battens to connect the dots. I used a 1/4" piece of oak with as straight grain as possible with no knots because that's what I had. You can use pieces of molding from the big box store that are clear and bend smoothly to the eye while looking down them from the end. After that, just cut on the line with a pull saw. It tracks perfectly and can make the long graceful curves for the planks.
I don't know if/when I'll ever get around to making a duplicate of either boat since there's always a new/different boat to build. I can see it would be cool to have two EP's to race with once my son gets older, but by that point I hope to be going camping with him in a NanoShip 3.0. I also have never seen a discussion on what the royalty owed to CLC would be for a second boat that's anything less that buying another set of plans.
I hope this helps. Good luck with your build!
