Quick question:
For the "Camp Seats", is it the same process - 3 coats unthicked epoxy then varnish ~ 5 coats or just varnish without the epoxy?
I assume since the seats will not be sitting in water but occasionally wet, the epoxy may not be as important, but I might as well do it from the beginning if it will make a difference.
