I completed the end pours using cardboard dams. I covered the inside of the dam with plastic shipping tap. A small leak occurred in the stern which I was able to stem. However the tape is covered in cured epoxy. I have been able to move most of the tape using a small chisel and needle nose pliers. Do I leave the cardboard or attempt to scrap/chisel it off?
Will it stress you to leave it? Or can you put behind you? If you are worried about having the ugliest end pour, don’t worry, my last one was a minor disaster and I’m sure it is way worse than yours. I don’t care - I can’t see it while I’m paddling.
One thing is if it’s bits of cardboard you may want to coat them in epoxy just so they don’t mold.
For me, i would scrape or chisel out or, as suggested, paint with epoxy so it does not rot.
A sharpened flat blade screwdriver and rubberf mallet will make easy work of it.
H
Howard,
Thanks. I didn’t think about the rotting part or mold/mildew.
Rob
Steve,
I will scrap off what I can with a long handled, sharpened screw driver as Howard suggests and take your advice and epoxy what’s left over. Thanks.
Rob
A dremel tool, with an abrasive bit, if it can reach it, would also make quick work of it.
I do have a Dremel tool but it is a larger model. I thought of using it with a cutter tool but thought of all the damage I could do. I’ll use an abrasion bit instead at least where it fits. Or use this as an excuse to get a smaller model.
Rob
