Center bulkhead is higher than plywood side
Eastport nesting dingy. Center bulkhead is higher than plywood sides. Is this normal. I assume I align side rails
Center bulkhead is higher than the plywood side. The tenons on the bulkhead stick out through the bottom and the side panels fit correctly matching the shape of the bulkhead. Is this normal? I assume I align the gunwale even with the top of the plywood sides.
