Chesapeake 17 LT DONE
Last bits and pieces installed. Weighed the boat and it is 51-52 lbs.  Ok, how did I do?
I will update the pictures shortly.  No, it hasn't seen the water yet, probably either tomorrow or this weekend.  If this weekend with two other similar boats that are 5 years old. I will transport to Tampa.
It has been a very fun project from start to finish.
Thanks all for the support.  I am a happy camper!
Dan-Fl
Congrats!  How long did you work on it?  I just glassed the hull of a Mill Creek 16.5 last night.  I started on April 3.
Received the boat and began working on it about November 15th. About 2 months this winter was just not good enough weather, so that was the time frame. I am guessing somewhere around 80 hours plus or minus 15%.
Here is a slideshow of the building of the above kayak.
<embed type="application/x-shockwave-flash" src="http://picasaweb.google.com/s/c/bin/slideshow.swf" width="288" height="192" flashvars="host=picasaweb.google.com&hl=en_US&feat=flashalbum&RGB=0x000000&feed=http%3A%2F%2Fpicasaweb.google.com%2Fdata%2Ffeed%2Fapi%2Fuser%2Fdcgralnick%2Falbumid%2F5417358361200239105%3Falt%3Drss%26kind%3Dphoto%26authkey%3DGv1sRgCLaHzZuZxf_KsgE%26hl%3Den_US" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed>
That embed did not work, lets try this Url.
Copy and paste in an address bar and you should get the pics.
http://picasaweb.google.com/dcgralnick/Chesapeake17LTDell?authkey=Gv1sRgCLaHzZuZxf_KsgE&feat=directlink
Dan-Fl
