I’m building the chesapeake triple from plans and am at the stage of placing the bulkheads. I have two main issues. First, at the bow and stern the keel and side panels do not want to come together. The gap at the bow is 1/4” and 1/2” at the stern. If I push moderately hard, I can reduce the gaps by about 50%, but I’m worried about going much harder than that. I’m pretty confident the panel dimensions are spot on.
Second, the bulkhead fit isn’t great. The dimensions should be pretty accurate, but I’m building from PDF plans and CLC only give you a 1” scale mark so depending on which pixel you measure from the total dimensions could skew as much as 1/2” inch (for reference my rear bulkhead is about 21.5 x 11 at max dimensions. With the bulkheads in place, the max beam sits around 30 1/8”, which is encouraging that the bulkhead width isn’t too far off. However, if I calculate the beam at each bulkhead from the image on full kayak on page 1 of the plans, it looks like I’m about 1/2”-5/8” too narrow, so perhaps the issue is the scaling off the bulkheads? Most of the height difference you see between the top of the sheer clamp and the top of the bulkhead can be attributed to the fact that my sheer clamps are currently about 1 3/32” tall, so they will get planed down to fit reasonably well there so long as I have the bulkheads push up snug against the sheer clamp. That of course leaves an even larger gap at the bottom. The keel is stitched pretty loosely right now, so if I push up on the keel line the gaps are reduced from ~3/4” to ~3/8”, so that helps.
So I’m wondering the best course of action. I’m not sure at all what to do about issue 1. For the second issue, it seems like I could either tighten up the keel stitching which should help some and then just let the filleting fill the rest of the gap, or I could cut new bulkheads to be slightly larger. Cutting new bulkheads would be easy to do, but I’m guessing I don’t want the bulkheads pushing out too hard against the side panels?
