This is a double decker trailer from Trailex that came with my CY and I need some advice on making it fit better. I attached some pictures to help. My thoughts are to remove the third roller from the midships as the bunks support the hull and cut the 60 inch front post to 60. Are the 4 little bunks oriented as they are good for my CY? I can't tell how the CLC Trailex is set up. Thanks for the advice. This boat is new to me and it appears well built and finished.
Jeff![]()
OOPS
Cut down the 60inch post to 30 inches.
Jeff,
You almost had it. When posting a picture hosted on flickr you need to use the static link from the download menu. To get that, click on the download arrow to get the download menu, pick one of the available sizes (I used medium for these) right-click on it and select "copy link address". Paste that into the image dialog box URL field on this forum.
Sorry but I don't know enough about the trailer to give intelligent advice so I'll leave that for a trailer expert.
