CLC Peapod build
   Does the manual call for attaching it with screws that you run from inside the hull up into the skeg? If you do it right, the screws should pull out most (or all) of that gap. Judicious use of wood putty filler will mak it all watertight and conceal the small remaining gap.
   I thought filling in with wood flour putty could be an answer. Glad to have confirmation. As for the screws, yes they could pull it close to the hull, but would probably make it bend (or break). In any event, thank you very much for your advice, very much appreciated.
   Hi Jose.  I have not got to this bit of my Peapod build yet.  However the manual does say to trim the skeg so that it fits snugly against the hull.  Your gap is bigger than I would have expected from the manual but I would try triming a bit off of the inside of the curve of the skeg to close that gap a bit before pulling it up closer with screws or relying on epoxy to fill the gap. Paul
Jose, I haven't reached that point but I just held the skeg up to the boat from below and I have the same condition in the same spot. It was all I could do to pull the stern together and I now see the dip that developed the gap just like yours. I don't recall this problem on the prototype at WB as shown on P.152 (that's me with my arms crossed) I agree with the previous posts. At this point take some off the skeg and fill with peanut butter. Gentle later when you install the screws and pull the skeg to the boat.  I'd like to hear from CLC on this. As I mentioned it was all I could do to pull the stern together...the last thing I was looking at was to ensure the skeg fit.   Dean
   It's good to know I am not the only one that had a hard time finishing the stern. It took quite  a few extra holes with copper wire and then quite a bit of filling and sanding. Like you, I though it all looked pretty good in the end until I dry fitted the skeg and notice the dip and gap. Thank you for the suggestions. I am putting this off for a while as in fact I have not yet reached this part in process. I just decided to do a dry fit of the skeg after fiberglassing the bottom and before flipping the hull, and was surprised by the gap.
Jose
   I'm still not ready to flip the boat. When I do I plan to fit the skeg as well as possible before fiberglass. I realize now not much of the stern can be removed so the skeg will need shaping. That, and good ole peanut butter as previously mentioned to fill the gap.
Keep us posted and I'll report back too.
Dean
   I plan to register my Peapod here in NC. I don't have to as less than 14' does not require it. However I will. So, has anyone thought about how to afix the HIN to the stern in a proper way that looks good ? Outboard starboard stern here in NC but your state may specifiy different...
Dean
Dean and Jose
Thank you for the heads up about your experience of the keel rocker not matching the curve on the skeg.
I have now got planks one to five and the ribs stitched together and on the whole it is looking good.  However I have noticed that the keel looks like it may be developing a slight reverse curve (or possibly just a flat section) about 12-18" aft of rib 5 just like the shape in Jose's photo.  With your experience I will be carefull to watch the shape here when I tighten up the stitches after attaching planks 6 and 7.  I plan to check the hull shape against skeg, centreboard case etc. before fixing everything in place with epoxy.
Paul
   Paul, you may be able to shave/sand off enough of panels 1 and 2 to reduce the curve. However I am not sure if that curve is supposed to be there or not.
   Update on the skeg fit: Yesterday I flipped the boat and could better see the 1/2" gap. After cleaning up the stern curvature I set the skeg on the boat to identify where to remove material. I moved the aft part of skeg slightly off the CL until it fit flush forward and marked the area to be removed. First thought was use the bandsaw. Too much commitment!
Break out the rasp...
After may trial fits it sits nicely. Interesting note 1/4" removed from the inboard side of the skeg drops the skeg about 1/2" onto the boat.
Cheers
Dean
   Thank you for the update Dean. So all the material you removed was from the skeg itself?
Jose,
Yes. Save for the little bit to shape the stern. Time to prep the bottom now.
Dean
Jose,
Dean
   Still a fair way behind you but over Christmas/New Year I think I managed to finish the stitching.  Seems like I had a similar experience to Dean, it was hard work getting the stern just so.  Bevelling the edges of the planks along the centreline join made a big difference.  Even so it took two attempts to close the gaps where the notches are cut at the end of planks 4 to 7 - I am on pause while I consider whether a gap less than the thickness of a matchstick is too big to 'hide' with filler or whether I need to backtrack a bit and try again to get a light-tight join possibly shaving a bit off of the upper edge of the planks where they fit into the rabbet.
I took the opportunity to test fit the skeg.  I have got a bit of a dip in the same place as Dean and Jose but it is much less than it was before I bevelled the planks along the centreline.  Thanks to your heads up about the potential problem I will use the skeg as a template when I get to the stage of the build where the stem and stern get shaped (after glassing the interior and before glassing the exterior).
On the bright side  it is now looking like a proper boat😀
Paul
   Paul,
On the stern joint gaps: I asked CLC about this and they said up to 1/8" no problem. I used that as a guidline and coverred with woodlfoured mix. That took care of it.
Thanks Jose
That's good to know and is consistent with the advice I have had from the UK supplier.  Gaps of that sort of size would not compromise strength - but would be cosmetic if one were going to varnish the outside.  They suggested big clamps (or planks top and bottom and a Spanish windlass arrangement) would squeeze the planks together that last few millimeters.  But I am going to stick where I am - fill gaps with filler and cover with paint later.
   I was inspired by the dyed floorboards and seats in the manual. There's alot of bright wood on this boat and I'd like to see some contrast. Also the centerboard trunk is so incredibly light I suspect it is not okoume and it needs some help.
I picked up a pint of General Finishes water based dye stain and did some 1,2,3..4 coat tests on a scrap piece of okoume. I like it and it was easy to work with.
Plan is floorboard, seats and centerboard trunk get color. Hull is a whole nother topic...
Thoughts? Who's adding color?
Dean
Dean,
Color:
I have just finished staining the floorboards with medium mahogany from mohawk and plan to do the same with the seats. It is rather dark but I think it will give a good contrast with a white hull exterior.  I am happy with that but this is all about personal preferences of course. The centerboard trunk looks good with several coats of epoxy and not stain. I plan to varnish it and so far it matches the oukume interrior.
   Jose
Sounds great. Send pictures when complete!
Dean
Further to Dean and Jose's posts above re the gap between skeg and stern.
I have just taken all the stiches out so can properly offer up the skeg for a test fit and lo and behold I had pretty much the same gap.
Talking to the UK supplier and a friend who is also building a peapod I am fairly certain that the answer is (or would have been) to cut a bevel along the last 12-18 inches of planks 1 where they join to form the centreline.  It's not mentioned in the build manual but it would be consistent with the guidance in the Gougeon Brothers' book on boat building.
It would help the planks sit nicely against each other rather than slipping over each other and I think it would stop the last few inches of the keel join 'bulging' out (there is a similar bulge/dip at the bow).  It is well too late for me to do anything about it now so like the others I will be triming the skeg to fit and also using the skeg as a template when I came to shape the stern..
