I’m using MAS epoxy. My fast hardner in a 1 gal bottle is running out. The slow hardner in the 5 gallon bottle is too low to pump. Can I pour the slow hardner into the fast harder bottle?
Yes you can. You'll end up with a medium speed hardener. Exact speed will depend on the actual mix.
You can also try measuring cups (disposable) when the epoxy and hardener get too low to pump.
Have fun,
