Still thinking about the frames…. I have dug thru this forum and found tons of examples back 10+ years ago with the same problem. Anyways I got the boat all lined up well and I just CA tacked everything. Then I pulled the wires for 1 and 2 planks and it is solid. CA worked like a champ. Tomorrow I will flip, ca tack the frames, flip again and start the glass work.
Alright some fun side quests while I wait for epoxy to cure:
- Clamp prep: With Black Friday coming up I have to know, do I have enough clamps…. Trick question (say that in Dwight Shrute’s voice) a true woodworker, dare I say boatbuilder, knows you can never have enough clamps!
- Paint: Wife and I have settled on a slate blue/grey color but now I need to figure out how to get that color…. Any ideas on who mixes or an online calculator to tell me colors to mix? Plan is to only keep bright work to highlights so the inside hull will be off white.
You have more than me and I’ve nearly finished a Southwester Dory.
I mixed my own paint and I’m happy with it, but it took a lot of trial and error. George Kirby Jr. Paint Company can mix any color you want. In future that’s what I would do. Someone else recommended this to me after I had already bought a lot of expensive paint.
It just occurred to me that the slate blue gray color you and your wife like is very close to the Blue/Gray Interlux PreKote primer I used on my boat. You could put a few coats of this on and then hit it with a few clear coats, it would be easy and look nice. A lot of people complimented me on the color of this primer thinking it was paint. It is just primer though, I recommend doing some tests before you commit.
