What's the best way to cut the nylon webbing loops so they won't unravel? Have most of you been using something like a heated utility knife, or is it easier to first make the cut with a cold knife and then hold the cut end near a flame to melt the loose fibers together?
razor and candle ,to make the holes i use a philipes head screw driver heated in the candle and pushed through the webbing into a hol drilled in the bench
I set up our MSR propane camp stove, and held a utility knife blade in a pair of vicegrips. The high temp of the propane got the blade nice and hot. I then heated a large diameter nail for the holes.
I use a soldering gun with interchangable tips. The knife tip cuts the material and seals it with one easy pass. The round tip drills and seals the screw holes in a jiffy. -Wes
I use Chris' method except I use a propane tourch instead of a camp stove. I also make the pieces long enough to double over both ends rather than one as recommended by CLC. It takes about 4" of webbing. Works great.
i just used a pair of side cutter (used for wire) and melted the edge with a soldering iron and used the iron to make my holes after i folded the end and they stay folded. you can squeeze the folds when still hot works great
