The instructions for my wherry say to rub everything with denatured alcohol (methylated spirits here in Australia), but a test on a hidden spot left the epoxy soft and tacky. Is this step necessary? Any experience? Thanks
Scott
Scott
Scott,
That sounds as if your epoxy hadn't finished curing before you cleaned it. Once the cure is complete the alcohol has no effect on the epoxy.
The reason to use the alcohol to clean the boat is that it dissolves oily deposits (like finger and palm prints), picks up fine dust and quickly evaporates from the wood. I've been using it for over 10 years and have had no problem with it. It's my cleaning liquid of choice for woodworking projects.
Just make sure your epoxy's cured and have plenty of ventilation.
Hi Laszlo,
I applied this epoxy several months ago (as far back as March - I know, this build is starting to drag on) so I can't imagine that it hasn't fully cured. I have looked into what denatured alcohol is called here in AUS, but I wonder if the formula mightn't be the same. I'll check with my local chandler and see what they say.
Thanks for your help.
Scott
Sometimes if the 2 part epoxy mix is not mixed well enough or not enough hardener is used, the epoxy may never set.
Thanks for your thoughts. I'm absolutley confident that they epoxy was mixed thoroughly. I asked a friend and local shipwright and he wondered if the eopxy returned to a hardened state and it did. I'm still wary, and I've asked this before, but is the alcohol rub critical? Some have suggested soapy water and a good rinse prior to varnishing. Any opinions.
Scott
I'd do a web search of your resin manufacturer and see what they say. In any case, it sound like your methylated spirits has something that U.S. denatured alcohol doesn't, and I wouldn't use it any more.
Here's an example of West System's advice on final preparation from their FAQ:
"Rub" with .........................I think you are reading that wrong......or it is too strong a word.
"Wipe" with denatured alcohol dampend cloth might be a better description. I've never had a problem with it. It is more of a tack cloth than a "rubbing" or soaking operation.
I have often used paint "thinner". Something that cleans and evaporates without leaving a residue.
.......but be careful it may "cloud" the finish. (where's the edit button?)
Methylated spirits is what we call methanol here in the usa. What they sell here as denatured alcohol is ethanol with something added to it to make it poisonous so you can't drink it. That might be your issue. I any case the alcohol wipe is not a requirement. For just cleaning wood or epoxy without raising wood grain you can use mineral spirits. For removing blush from epoxy before varnishing, you can use a soapy water wash or a diluted ammonia-water rinse.
Coco:
Here's what I think about your problem, from everything I've read as a curious amateur over the years.
1. Cured epoxy is impervious to methanol and to ethanol (denatured or not...the additives are only chosen for their ability to make you vomit and resolve to repent of your evil bootlegging ways) (and to acids, bases, polar solvents, non-polar solvents, reducing agents, oxidizing agents, and almost everything else). So if methanol or ethanol softened the finish, that finish was not cured epoxy, for whatever reason. We all make material selection/mixing/application mistakes and don't always discern them after the fact.
2. If your finish is cured epoxy and you put something on it that softened it, then that something wasn't just methanol and it wasn't just ethanol. I know that properly cured epoxy isn't impervious to everything, since some specialized products are sold that remove it. But it seems unlikely that those specialized chemicals that do would be included in the formulation of a general purpose methanol or ethanol-based solvent, even in a free-spirited land like Oz.
So, whether the OP is correct (Oz.MethylatedSpirits == US.DenaturedEthanol), or NYyaker is correct (it's methanol, not ethanol at all), it can't attack cured epoxy.
If denatured ethanol really could attack cured epoxy, it is almost certain that people with long professional expertise in both epoxy chemistry and boatbuilding with epoxy (like Laszlo) would have experienced it.
I am not an expert in this subject and these are only my speculations. I hope you will share the results of your further research into the mystery.
Will Isopropyl alcohol work or is it different than denatured? (Have lots of isopropyl)
100% isopropyl should be ok but might prove to be pricey. Most isopropyl is watered down to some extent and drug store or rubbing alcohol should be avoided like a tax audit. Also, I read somewhere that it should be used only for wiping down bare wood and epoxy, not varnish. You should check the manufacturer's recomendations for application tips. I use Interlux solvent 333 to wipe down between coats of Interlux Schooner #96.
I noticed the same effect as the OP: I wiped down cured epoxy with Denatured Alcohol and the surface got tacky. It didn't last long, the effect disappeared a few minutes after the alcohol evaporated, but it did happen. I am using Kleen-Strip brand Denatured Alcohol from Home Depot in Los Angeles. We are subject to the regulations of the Air Quality Management District, so our CA formula may be different from that used elsewhere. BTW, the epoxy had been cured for about a month and was hard as nails.
I forgot to mention that this happens to every epoxied part: no matter which batch it is from, no matter when I mixed it. Now I could have miscounted the 1:1 pumps from the MAS dispenser once, maybe twice(I doubt it), but to think that every single time I mixed the stuff I miscounted seems unlikely. I simply cannot deny the repeated evidence of my own eyes and fingers, no matter how many post that "epoxies are impervious to alcohol and solvents". The epoxy might be impervious, but SOMETHING is temporarily happening to it.
I am very interested in your observation of alcohol makiing cured epoxy tacky! It goes against everything I have read. It might be worthwhile to inquire on West Systems' website. There has to be a scientific solution to this puzzle.
I've never seen denatured alcohol (at least what is called such in 'Murca) soften epoxy.
The only thing I've seen do that is lacquer thinner, and maybe acetone, and even then it took a LOT of it. At intervals we pile all of the shop C-clamps in a 5-gallon bucket, pour in a gallon of lacquer thinner, and clamp the lid shut. A few days later, we can get all of the epoxy off the screw threads with a wire brush. Lacquer thinner is a very nasty chemical and strenuous precautions have to be taken.
What brand epoxy are you using?
John,
I am using the MAS epoxy that came in my kit. Let me hasten to say that there has never been a problem with the epoxy on my kit. I just wanted to chime in and post my observations. The alcohol wets the surface one is wiping, it then evaporates, but the surface of unsanded epoxy is tacky to the touch for a period and then returns to its normal condition. I will have to experiment to see if the same thing happens to sanded epoxy. Maybe it is some sort of "blush" that is reacting with a denaturing additive in the alcohol, there are literally hundreds of them I have read.
I will toss some hardened peanut butter I to a bowl of alcohol for a while and see what happens....
I soaked a half moon of cured peanut butter off the lip of a solo cup in my alcohol for an hour or so. The wood flour and epoxy cured about a week ago and was hard and brittle. After an hour in the cup I could bend it almost 180* before it broke. So there is SOMETHING going on....... Despite what the experts proclaim, I have to believe my eyes. Epoxy is NOT impervious to denatured alcohol
