I need to build a dinghy cradle for storing my CLC Ultralight on the cain deck of my trawler. I have ideas for the design but I though I would post the topic here for any who has done this or has original ideas to give comments.
Here's what I did (dinghy say on aft deck roof): I took two pieces of leftover R10 foam and whittled away at them until they fit the shape of the hull, one fore and one aft. I then used those as templates to cut out appropriate sized pieces of big box store lumber. Coated in epoxy. Through bolted (drill-fill-drill with butyl tape) onto roof. "Caulked" where the wood met fiberglass with thickened epoxy, then painted the brackets.
Sorry, I mixing up two differents projects. Lag screws from the underside of the cabin roof, through the fiberglass into bottom of the wood cradle brackets. Not thru bolts.
