double-checking internal footbrace placement
Friends,
Per the instructions, the internally mounted footbraces are to be located 2" below the sheerline, some 38" forward from the aft bulkhead. That places them a mere 1" below the bottom of the sheerclamp. Looks awfully tight to me (and I have small feet).  Am I missing something? 2" below the sheerclamp's bottom looks better to me.
Sugestions/observations appreciated,
John
what are you building?
To clarify; I'm building a Chesapeake 16LT.
John
Before I put the deck on my shearwater 17 I sat in it and found the most comfortable position for the foot braces
My ch17 says  2" below sheerline but the adjustable footbrace instructions says 2" below sheer clamp. I am sure the latter is correct.                  Good luck, Pete.
Thank you all,
John
