Eastport Pram question
Hi,
 Can the Eastport Pram be loaded by one person on a roof rack?
 Thanks,
 Alex
How old are you?  Are you fit?  How much do you weigh?  What is your support equipment?  Do you have the appropriately rated tie down system at roof top (or wherever).  Can you control a hundred pounds of dead weight by yourself?   if yes, can you control 120 pounds?  If you had to think about that, you need a partner.  Two is always better than one, especially as the age:experience ratios apply.  This from a 61 year-old.  Thirty years ago I’da told you "hell yeah you can do it!"  Now?  Your call.  best,  bob h.
