Looking for advice from anyone who has installed an electric motor in the southwester dory motor well. Currently considering an epropulsion spirit 1.
I can’t offer advice, just now starting my own SW Dory. I plan to use the ePropulsion Spirit 2, short shaft. I’ve heard there is a place in Atlanta that has one in the show room you can look at. That is not to far for me, I may just tow my boat down there and and see what fits.
Jon I have pretty much settled on the spirit 1 short shaft. Will be looking at one tomorrow to make sure I get the well cutout in the best position. I expect I won’t be able to swing it up into the well, shaft too long. But otherwise it fits well enough especially if I purchase the remote battery option which involves an extra long power chord to the spirit battery located in the stern storage. That way the motor profile is reduced with a small cowl in place of the battery. Will let you know more as I learn more.
Curious if you bought the motor and if it fits/works? Just started my SW Dory build.
On the last day in October I ordered the motor well kit, the sailing kit, and a trailer from CLC. CLC says these won’t be shipped till mid December. Business must be booming.
The motor, batteries, and chargers are the last big purchases for my boat. I’ve had a few brief email exchanges with Tiny Boat Nation about motors and the final email said the ePropulsion Spirit 2 should work. Really the Spirit 1 would probably work too for a fraction of the price but I’m hoping for a little more range and you get 20% more battery capacity with Spirit 2. I’ll never need all that output and I’ll probably putter along at hull speed on a fraction of the motors capability.
My plan currently is to save money all fall and winter and order a Spirit 2, and a spare battery in late winter early spring. This alone would carry a Southwester Dory miles and miles. EMO sells a fast charger for the Spirit 2 battery and I’ll probably order one of those from them. I’ll slow charge mostly from home but having a fast charger aboard means I could top up at a marina or campground which is a luxury.
The Spirit 2 comes in long shaft, short shaft, and short-short shaft. I’m guessing the SW Dory fits the short shaft best but till I actually build the motor well and drag the boat down to TBN in Atlanta and test fit, hard to say. @dcapizzi was concerned the short shaft Spirit 1 wouldn’t be able to tilt in the motor well. I’d be interested to hear how that all turned out.
Enjoy your SW Dory build, I hope you share pictures. Nice to know I’m not alone out here.
Hi Jon
I looked at some of your photos. Nice work.
I decided the new spirit 2 was more than I needed. My challenges on installing the spirit 1 were length of shaft and placement of the hull cutout. I went with the short shaft and the clearance of the motor/prop from the bottom was just right without any adjustment to the transom height. I also visited a seller to measure the distance from the clamp to the forward edge of the shaft (set at vertical position to the dory’s transom angle) to get a more exact measure for the forward edge of the cutout. No way to provide a long enough cutout to tilt out as I expected.
So the bother is having to drop in the motor after launching and pulling it out before putting it back on the trailer. The battery is remote in the aft compartment so not too awkward weight-wise. But a small price to pay for the quiet propulsion. Works great and decibels are less than a good dishwasher.
Best
Derek
Hi David
Best
Derek
Awesome Derek! Any photos?
It’s the backlog from the Fall Kit Sale. Happens pretty much every year.
It’s a good problem. I want CLC to prosper. I want this hobby to gain popularity.
