electric outboard on Annapolis Wherry Tandem
Any ideas ?Did anyone considered adding a small electric outboard like the  torqeedo Travel 1003 CL to the Annapolis Wherry Tandem?
Call Linda Grez 425-985-6625. Much better solution. Electric outboard that weighs less than 15 lb with battery. I have one and the quality is beyond reproach.
Website is electricpaddle.com. And the weight is 21 lb instead of 15 lb. You will be pleasantly surprised.
   Any motor on the Wherry would be a complicated thing. You could not sit aft enough to handle the tiller or throttle on the motor. The  Wherry is designed for folks to sit at the rowing stations. To sit aft enough to handle a  motor one would need a passenger sitting almost in the bow. Very very awkward. consider picking another design.
Joel
Tiller extender + ballast in bow to balance motor will take care of that when solo.
When rowing with 2, the ballast may not be necessary.
CLC used to sell Eletric Paddle. It was a smaller model then. Don't know if they still do.
