Epoxy 2nd coat question?
This is from the MAS Epoxy website - FAQ
What is the recoat time?
Since epoxies from MAS are 100% solid (no solvents), recoat time can be as short as it takes to achieve surface tack. If more than 12 hours passes between coats, do a light scuff sand. Use a cotton ball to test if a light scuff sand is needed. If the epoxy holds the hair of the cotton ball, you can recoat without sanding. If it doesn’t, a light scuff sand will help adhesion between coats. Remember the “Rule of Thumb” test (if you can press your thumbprint in the epoxy, but there’s no tack, then you should do a scuff sand, but will be getting a chemical as well as a mechanical bond.) Remember, warmer conditions make for a faster cure time. Review the chart in FAQ 5 to see an estimated cure schedule for the temperature you’re working at.
   Thank you Oceanluvr
