can the epoxy on the hull be sanded before placing th deck glass and epoxy. i had to fill a gap between the deck and hull. if i sand off the what ended up on the hull will this affect the finish?
It'll be fine as long as you don't sand into the wood.
Thanks for the vote of confidence. I don’t really have a choiceI have to sand. I’ve just never workrd with epoy before so I’m not sure what can be done. It sounds lo=ike I can work it like any other clear finnish. thanks again
