At the 8-18 CCWBRA races for SKUAs someone mentioned use of a resin/hardener application where cartridge tool mixes as applied. I researched and found something called Pro-Set. Has anyone used such a product. Thoughts?
LAR
LAR
Haven't used Pro-Set. West System's Six-10 (CLC sells) comes in a cartridge. It takes six to eight cartridges to complete the fillets under the kneeling platform of a Cocktail Class hull. Saves time but is pricey at over $20 per cartridge.
West's 610 comes in a single cartridge that fits an ordinary caulking gun. It is a slightly toughened (non-brittle), colloidal silica thickened mix, and uses disposable mixing nozzles. It's a great product for repairs away from the shop since it requires none of the usual list of implements- mix cups, stir sticks, containers of resin and thickener, etc.
Pro-Set's cartridges are double barreled jobbies, requiring a special (and expensive) caulking gun. However they offer a broader range of resin choices, aimed at the professional shop.
