Hi all --
I'm nearing completion of a Northeaster Dory, and have cut a bunch of 1-1/2" thick Foamular into 6" strips for flotation blocks. Next step is to epoxy three layers together -- I had assumed I'd coat the adjoining surfaces of the strips with thickened epoxy, but it now strikes me that that will be a ton of epoxy. Does anyone have any comment on using spots or lines of epoxy to tack the layers together? The outer surface of each block will be entirely coated with epoxy.
Ben
