Fiberglass delamination due to stress?
I finished my Oxford Shell II this winter. I car-topped it to my local club and rowed it twice. I then discovered these two lines down the bottom of the hull, running 4-5 feet. It looks like the fiberglass is delaminating from the hull as you can feel the raised texture on those lines. There’s a couple other small patches as well, but the long lines are concerning. I realize there is some other posts on this but I didn’t see anything quite like this. Any opinions why this is happening? The finish looked perfect before.
I have had something like this happen.
the case that appears most similar was due to heat from black tie downs and parking the boat in the the sun. when i removed the straps, which had apparently gotten pretty hot, i had a very similar pattern to your picture where the tie downs had been.
i have also experienced something similar in an area of a boat that was flexed significantly…but that took a couple seasons to appear.
If the boat was transported or otherwise set down/stored, was there anything that was touching the hull over the effected area that could have generated heat?
the bubbled/delam on each side, to me, are remarkable for their symmetry but don’t fit any pattern/cause of delamination due to epoxy mix or other causes that come to mind absent what i described above. was there anything else that ties these two areas together from a construction perspective - underlying structure or laminaton schedule?
Same for me. I’ve had this happen due to a dark brown tarp in direct contact with and edge on the boat on a hot/sunny day. I think the epoxy gets soft and the wood outgasses, that’s my only guess as to why this might occur. Preventing conditions that overheat the boat seems to be the only way to avoid. I now just live with that “feature.” Using the boats is more fun than refinishing them - although periodic maintenance of the finish is required. I keep most of my (11, of various types and sizes) boats outdoors, but covered (ventilated covers, avoiding direct contact with the boat using supports/battens, etc. if possible) and waxed. Some boats have garage privileges :slight_smile: Anyway, depending upon how much the boat is used, and how well you are able to avoid abuse, I find I’m making it about 5 years before going for a quick sand and revarnish (about 3 coats) or repaint (one topcoat) effort. When I get around to doing the boat that has the problem described above, I presume that I’ll be able to flatten out the pebble grain surface, but I think the speckles will alway be visible.
Didn’t want to imply all 11 of the boats are wood/stitch and glue…
Thanks for the reply - it was stored upside down on some low boys for a month or so, mostly shielded from the sun. It had a cover on it as well. I can’t think of anything that would explain those two lines from a heat perspective, such as a seam on the cover. The flaws do both happen to line up where the tabs of the bulkheads are notched into the hull. That made me think there is some kind of flexing on that point in the hull, but for as a little use as its had, that doesn’t seem right either.
yes i’m thinking i’ll let it go for a while and see how it progresses. It doesn’t seem to need urgent fixing from a seaworthiness perspective. 11 boats - wow!
