Greetings,
So the incessant high plains winds of Colorado are to blame for some damage to my Kaholo 12-6. It was either my elbow or my paddle that crushed a section of the deck when a gust took me clear off my feet last weekend.
I also can't determine if the dent/crack that's there extends all the way to the wood or if it's just a dent/crack in the varnish or a dent/crack in the glass. It's hard to see in the pictures but there is definitely a depression along with the visible damage. If you look closely you can see the weave of the glass in a portion of the damage.
Curious the best route to take to repair and if I should avoid water until it is repaired (again, I can't really tell if the damage extends all the way to the wood)
https://www.amazon.com/photos/groups/3kUTwF7NQk-jfINWMIYpgg.
Patrick
